changing drum brake shoes
Old Sep 21, 2011 | 12:24 PM
Default changing drum brake shoes
I think its time to change my brake shoes on the rear. with 80k coming up they are starting to sound like a trash truck with stopping at low speeds (like in a drive-thur)
so i went to take the drum hat off and it wouldnt move!
I noticed to screw holes that it some bolts with to be put in they would press against the axel. is that how you get the hat off?
any help would be nice
also it that is how you get it off what size bolt is needed?
thanks
Old Sep 21, 2011 | 01:52 PM
mhotrodscooter's Avatar
Make sure you don't have the E-brake on & beat on the flat surface where you bolt the wheel on. It should loosen it up. Also remove the retailer clips if you got them.
Old Sep 21, 2011 | 01:58 PM
Preston129's Avatar
I took mine off using the bolt holes, can't remember for sure but I think it's either an M10 or M12 bolt...just be sure to thread each of them evenly when you start tightening them.
Old Sep 24, 2011 | 09:18 PM
drperry's Avatar
This!
Once you get the drum moving a little bit, you should be able to just pull it loose.
Old Sep 28, 2011 | 10:35 PM
Leevon's Avatar
Since I banged on my drum for 5 minutes last night before I realized the parking brake was on, I agree...start there
Remove the parking brake cable from the retainer under cab outside the frame rail. The big spring that holds the pad down is tricky, it took me awhile to figure out how to remove and re-install.
And I hope you don't find a leaking axle seal that trashed the shoes like I did
Old Oct 4, 2011 | 11:48 PM
drperry's Avatar
Why remove the parking brake cable from the retainer? I've never had to do it for drum brakes before...
Something they changed in this design?
Old Oct 5, 2011 | 07:19 AM
Check out the how to I wrote on the gmt900 area
Oobray
Jun 13, 2022 03:38 AM
Corvette454l88
Sep 1, 2016 01:24 AM
therock
Aug 20, 2015 02:31 PM
97aztecgt
Aug 13, 2015 02:11 PM
