bump stops for 4" rear drop
Old Jan 22, 2010 | 06:55 PM
wallyj's Avatar
Default bump stops for 4" rear drop
Bought an 07 RCSB Chevy last weekend. Order the McGaughy's spindles and leaves/shackles for a 2"/4" drop. Plan on installing this weekend. Got to looking at the bump stops in the rear. Looks like 4" will put the bump stops pretty close to the axle. My first instinct is to cut off the mounts and bolt a shorter stop to the frame. What do you guys do?
__________________
Old Jan 22, 2010 | 08:31 PM
SILVERADO11's Avatar
I see alot of guys C-notch the frame for clearence. some just cut the bump stops down but you may bottom out with any weight in the bed and ride like ****. c-notch is the way to go.
Old Jan 22, 2010 | 10:59 PM
wallyj's Avatar
Thanks. I guess I'll start with cutting off the stops and see if I need to do the notch. Don't really want any contact there so if that's what it takes, I'll do it.
Old Jan 22, 2010 | 11:04 PM
Mang213's Avatar
that 4" drop shouldnt be much of an issue considering how high these trucks sit when stock. Cut the stop in half and I think you'll be fine
Old Jan 23, 2010 | 04:10 AM
Beyond Static's Avatar
cut the metal bumpstop bracket off the frame. You'll have about 6" between the frame and axle once you do that.
Old Jan 23, 2010 | 08:53 AM
JB1's Avatar
JB1
word just cut the drop bracket metal off, drill a 3/8 hole in the frame, tap it and screw the factory bumpstop back the frame
wallyj's Avatar
Thanks for the input, guys!
Old Jan 23, 2010 | 08:56 AM
wallyj's Avatar
That is what I was hoping would work.
By the way, your truck is absolutely perfect. I can't think of how it could look better.
Old Jan 23, 2010 | 09:04 AM
lowoh8's Avatar
lol too bad he lifted it and it doesn't look like that anymore.
i bought some small bumpstops from pepboys, gotta tap the frame and put em in. i'll get some pics
Old Jan 23, 2010 | 10:13 AM
wallyj's Avatar
There is a pep boys right up the street. Guess i'll run by there before I start her in a bit.
