blue smoke
Old May 13, 2013 | 10:42 PM
JCunningham's Avatar
Default blue smoke
Guy from work was behind me and told me when I got on it he saw blue smoke. I noticed when I had my tb ported that it had oil on it and the SC and tube had oil in them. Im thinking it has to be coming from the breather on the valve cover. Do I need a catch can? is this normal?.
Old May 14, 2013 | 04:32 AM
03sierraslt's Avatar
You need a catch can.
Old May 14, 2013 | 05:39 AM
Choda's Avatar
I just got my mile Norris can on Friday
Old May 14, 2013 | 07:21 AM
slow2008's Avatar
formerly slow03 (11-04-2011)
Ok, so this is normal with the 6.2's then? I've been getting a little worried and only have 1700 miles on mine.
Old May 14, 2013 | 08:01 AM
drummer0415's Avatar
Blue smoke means burning oil. Oil coming from the PCV system and being sucked into the intake is normal on just about every LS motor. A good quality catch can will solve your problems.
Old May 14, 2013 | 08:58 AM
Cool thanks . Are some better then others?
Old May 14, 2013 | 10:23 AM
ok after searching How do I hook a catch can up to a Magnuson tvs1900 supercharged 2012 6.2l
Old May 14, 2013 | 10:51 AM
You should have a fresh air hose going from the intake tube to pass valve cover and a hose going from the drivers side valve cover to one of the nipples on the blower inlet. The catch can will connect to the hose that runs from the drivers side valve cover to the nipple on front of blower. Valve cover to catch can, catch can to blower nipple.
Old May 14, 2013 | 11:12 AM
im sucking oil out the pass side valve cover too I think. when I took my tb off it was covered in oil. I just checked it now and its dry
Old May 14, 2013 | 05:57 PM
i think ill get this one. I like that the bottom unscrews so no drain valve.
PCV Oil Catch Can for 1997-2004 C5,C5 Z06, C6 LS2 and Z06 Corvette
