Better radiator options?
Old Feb 17, 2015 | 08:37 PM
Gray Ghost Silverado's Avatar
Default Better radiator options?
Hey guys, I've gotten to the point of maxxing out the cooling capacity of the stock GMT900 radiator in my truck with the addition of the 427, decent cam, turbo piping and all the other crap packed under the hood.
Do any of you know of a drop in all aluminum radiator with more cooling capacity than stock? I don't need one with the trans cooler or oil cooler end tanks on it anymore as all of that has already been addressed, but I will take what I can get.
Thanks,
-Robbie.
Old Feb 17, 2015 | 08:48 PM
GMCtrk's Avatar
What thermostat are you running? What coolant? What are the temps doing
Old Feb 17, 2015 | 09:08 PM
160 degree thermostat. 70/30 mix distilled water and GM Dex Cool. The temps idle at 190 on a cool night, and cruise at 178-182
At day time though with the A/C on it'll idle up to 216, and cruise at 205+
Too warm for my tastes for the kind of $ I have in the engine.
Old Feb 17, 2015 | 09:38 PM
GMCtrk's Avatar
Looks like you've done everything right. And i agree those temps are too high.
im also running the 160 tstat, 70/30 mix and the aftermarket all aluminum 34" 2 row rad.
Its a beast of a cooling system with the oem fans and honestly is too much in cold temps. But its perfect in texas summer. Will run upper 160s going down the highway and idles where i have the fans come on at 184.
Old Feb 17, 2015 | 09:54 PM
George C....'s Avatar
Formerly ScreamingL
have you tried to get the heat out of the engine bay? tight quarters will always be hot reguardless of rad size
Cowl hood, less plastic parts, vents all would be helpful, heat shields and possibly try double wrapping things
Old Feb 17, 2015 | 10:32 PM
GM_Devil's Avatar
who makes that radiator youre using?
Old Feb 17, 2015 | 10:37 PM
GMCtrk's Avatar
China (I'm guessing - was $170 I think). Surprisingly good quality though, OEM fit and all.
thompson
Dec 27, 2017 06:48 AM
old motorhead
Sep 29, 2015 08:22 PM
TrickTurbo
Sep 25, 2015 11:22 AM
Closer_2001
Sep 24, 2015 09:15 PM
whitelazer
Sep 22, 2015 09:38 PM
