Best way to wire in a 2-step?
Old Aug 8, 2016 | 06:05 PM
TAPyvehc93's Avatar
Default Best way to wire in a 2-step?
I like the idea of wiring it into the brake pedal but I think it would be hard to do a burn out. Only a footbrake here. Any ideas?
Old Aug 8, 2016 | 06:55 PM
Jake75's Avatar
i wired mine into the trailer brake wire (yellow wire at trailer plug) and hooked it up to a switch so the 2 step was only active when the switch was turned on!
Old Aug 8, 2016 | 07:07 PM
TAPyvehc93's Avatar
Haha, thats what I just read online. Thats the way I will do mine also! One thing I noticed when I was just out test the two step was that when I had the truck in neutral and on the two-step it sounded like the typical two step (like a popcorn machine). When I had it in drive and on the two step I couldn't even tell if the two step was working or not. Its normal? I guess I was just expecting the typical two-step noise.
Old Aug 9, 2016 | 05:43 AM
Jake75's Avatar
When I tested mine on the two step in neutral it made some pretty dam good 2 step noise (sounded like gun shots) in drive it was really quiet. I have a video I'll find and post of my truck on the 2 step in drive.
Edit-
Old Aug 9, 2016 | 07:07 AM
TAPyvehc93's Avatar
Edit-
2 step 2900 rpm 5 psi - YouTube
Yep mine sounds the same. What size converter?
Old Aug 9, 2016 | 01:19 PM
Jake75's Avatar
3600 Circle d
NSSANE02
Sep 6, 2016 12:22 PM
NSSANE02
Sep 5, 2016 03:26 PM
GM1697
Aug 17, 2016 07:05 PM
carid
Aug 5, 2016 06:44 AM
Haulinbass02
Jul 20, 2016 03:00 PM
