Belltech drop struts
Old May 17, 2009 | 05:42 PM
Beyond Static's Avatar
Default Belltech drop struts
Anyone have experience with them, and exact measurements of the drop amount they got? I'm trying to keep the same ride height I had with mcg's 2" coils and stock struts, but am still 3/4" higher with the belltech struts and no spacers or bumpstops on them. Anyone mount the lower mount of the strut under the LCA instead of on top? I know this would put more stress on the contol arm and the bolts to secure the strut to the arm, but has it been done?
Old May 17, 2009 | 08:05 PM
JB1's Avatar
JB1
your MCG coils were probably sagged to 3", heard alot of complaints on MCG coils. I got exactly 2" with my struts and no spacers, then I added a 1" ground force drop coils when I was at 5" front drop.
Old May 17, 2009 | 08:07 PM
RandomHero's Avatar
LOL, you really hate McGaughy's don't you.
Old May 17, 2009 | 08:08 PM
That's kind of what I figured. Did you see how little travel that strut has left with no spacers? The aftermarket bumpstop sits on the shock body. I'm sure you removed or cut down the bumpstop to add a drop coil
Old May 17, 2009 | 09:59 PM
JB1's Avatar
JB1
ya the instructions on mine said to cut the bumpstop...rode good though
Old May 18, 2009 | 09:09 AM
gdev_'s Avatar
I JUST got done swapping out my POS McGaughys 2" coils. I put the BellTech 2" coil and the BellTech strut back in it's place, with the BT strut set to "1" lower than stock" (for a total of 5" in the front now, I have the MCG spindles as well), and it's roughly 1.25" taller than the sagging MCG's that were just removed, that were supposedly a 2" coil. Go figure, the truck rides better, and is actually aligned again!
Old May 18, 2009 | 09:15 AM
a_guerrajr's Avatar
full 2" on my truck also.
Old May 18, 2009 | 10:37 AM
ctuck6's Avatar
How is the ride with these struts? I currently have 2" spindles and I am wanting to go to a 4" drop in the front.. what is ya'lls opinion... 2" struts or coils...
thanks,
Chris
Old May 18, 2009 | 01:50 PM
a_guerrajr's Avatar
i have 2" Ground force and it rides pretty good with spindles. the struts ride pretty good also.
Old May 18, 2009 | 04:02 PM
Occupational_Hazard's Avatar
thought you couldnt use the drop struts with drop coils. i didnt know whether or not to but the struts. But was thinking about a coil/lca/drop strut combo tho
