available cams for 6.2L sierra
I want to know what cam is available for my truck? I want a good lope and great performance. I don't tow anything or play in the mud. It is lifted 3 inches and has 33" tires on 18" wheels. I have 3.42 gears....only ones avail. last year with the 6.2L....anyway if I changed the converter I know it would help realize the full potential of the cam, but I don't want to hurt the truck in anyway. So....what would some of you other guys do....I usually lean more to the aggressive side of conservative
13 Second Truck Club
If you want to keep VVT tuning is super important, you can find horror stories of folks who kept VVT just couldn't find anyone to "properly tune" after the new CAM install... Good read here http://www.hotrod.com/techarticles/e...s_engines.html
This is the only shop that I know of that "understands" how to tune VVT besides Pat G http://www.engpwrsys.com/index.php?act=viewCat&catId=29
I like the Stage 2 CAM, COMP claims Substantial power and torque gains across the board...http://www.compcams.com/Technical/Ca.../pdf/page9.pdf
Agreed, him or Geoff at EPS are great people to work with, that will help you match a cam to your specific application.
I'm sure you can, but you're still going to have to live within the constraints of the VVT limitations.
The difference between spec'ing a cam and matching a cam is sometimes pretty negligible; the four cams Geoff has on his site range from 212 to 222 degrees of intake duration...is there really going to be a huge benefit from spec'ing one out with 223.5 degrees? It's not like we're all racing our trucks in prostock and every last horsepower counts.
It's hard to say zero bottom end loss when we don't have any data under 3500...I didn't mean 'limitations' like a vvt motor is only going to make half as much power as a non-vvt one, but you're still going to have a smaller number of cams to choose from, and possible issues with both PTV clearance (addressed mostly by the vvt phasers) and valvetrain issues with constantly changing valve events (will the valvetrain of a motor with constantly changing valve timing have the same longevity as one without? I don't know; probably not an issue on a street motor, but it still bears consideration).
I didn't mean Geoff is the end all when it comes to vvt and cam design; maybe he uses his own lobes for vvt cams, maybe not, I can't speak for him, but I'm happy with the cam he ground for me, as well as the dialogue we've shared which is why I brought him up.
