Anyone know of a paddle shifter for the 6l80e trucks?
#41
Gotta use gm switchs because they have resistors built into them and the tcm recognizes the changing resistance to command a up or down shift. And we are lucky the tcm/ valve body assembly as per gm is the exact same part number from vet to camaro to my 6L80 so our trannys do have the capability. If I don't hit a brick wall re flashing it. If I do I'm sure we could do a segment swap on HP tuners.
#43
Ok cool I'll try and order a shifter with the paddle shir and take it apart. Maybe I can move the factory switch to these paddles and go from there. Same resistance just with a bigger paddle. Think that will work?
#45
The shifter on our trucks is just a N/O switch contact that goes NC when you push it and the bcm recognizes the change in state of the switch position.
#47
http://server11.texasdirectauto.com/...8/019_0019.jpg
#49
Not going to happen using a flash and simply changing switchs. You may be able to do it using hp tuners if you can isolate the tu/td programming and sub in the vette segment. Then it will talk to everything in our trucks like it's supposed and have the switchs.
With the vette flash in the TCM my truck acted like the retarded kid in the corner banging his head on the wall and slobbering constantly and the IPC looked like a 70's pinball machine.
But the tu/td switchs wired up in a temporary form did work according to my tech 2.
#50
what about putting a 2009 H2 Hummer Switch on it those switches on the back are the gear shift
2009 HUMMER H2 STEERING WHEEL CRUISE CONTROL SWITCH W/ HEATED WHEEL 25901034 | eBay
New heated wheel. there the saome as our wheel.
2009 GENUINE HUMMER H2 BLACK LEATHER STEERING WHEEL 25995628 | eBay
