6l80e Converter Swap - At Home
Old 03-11-2013, 04:05 PM
shaw_426hemi's Avatar
Originally Posted by bdubb
Get as big of a trans cooler as you can fit. You'll need it for the converter, but also for the towing.
I tow around 5000lbs on occasion with a 2800 Circle D through rolling hills. Haven't had any issues with it but it's not something I prefer to do often.
Yeah it will be getting a 40k cooler with a 10.5" triple disk. I really only tow 5,000+ a few times a year and as long as I keep the trans temps down I should be fine. Just wondering if 3200-3400 is too much or if I should go with that 3000-3200. Talked to chris at Circle D he said a 3200-3400 is fine. I realize its not much of a difference but I want to keep as much towing as i can while smoking the old lady's Audi A4 (she thinks its faster than my truck).
Old 03-12-2013, 06:21 AM
HAMMER!'s Avatar
Like they said get a big trans cooler and you will be fine! Towing with my 3500 stall isn't that bad, I just give it a bit more throttle to get moving to about 35mph then the converter locks and from there it's like stock pulling! The most I've towed was about 10,200lbs for about 40 miles and everything was fine. Also tow my camper (7k+) hundreds of miles a year, along with a trailer behind it with a ATV's on it. Doing a burnout with the excavator from RSC equipment rentals on trailer in front of their shop was awsome to cause they said my truck wouldn't pull good cause it's a gas burner!
Old 03-12-2013, 10:59 AM
NKPPhil's Avatar
Git some!
Old 03-13-2013, 03:24 PM
Ordered a 10.5" 32-3400 triple disk from Circle D today.
Old 03-13-2013, 07:55 PM
HAMMER!'s Avatar
Like!
Old 03-14-2013, 05:26 PM
Hoping it will pull hard once its installed and the tune is dialed in. Is a dyno tune worth the $500-650?
Old 03-24-2013, 09:54 PM
Picked up 2 gallons of synthetic ATF fluid for the swap, is that enough? Read 6 quarts for a flush but with converter coming out, trans cooler going in, I figure I would need 8 at least. Also picked up a drain plug I plan to install in the pan, anyone done a drain plug on a trans? Pics? Lastly on the trans filter and gasket, has anyone reused the stock gasket? Tech told me to reuse it, still think its best to replace.
Old 03-24-2013, 10:08 PM
06murder's Avatar
You always want extra tranny fliuld. Just in case you spill some or not enough
Old 03-24-2013, 11:21 PM
JCunningham's Avatar
id get 12qts to be safe. or you can always go get more. 6 qts to do a filter. 14qts for a flush. the 6 speed holds 12qts.
Old 03-25-2013, 09:57 AM
I will need some more then! THNX for the info
Quick Reply: 6l80e Converter Swap - At Home
