6.2L swap help
Formerly darynC-10/23/10
since I HAVE DONE THE SWAP...... its basically a strait swap deal. as long as ur using the l92 truck intake ,everything will be a direct swap. oh yeah .. just make sure u have your fuel rails from the l92. they bolt up differently .the tabs are on the outside instead of the inside....
Not sure on the 08's but the 09's all have the same fuel system afaik so they are good to go.
UPDATE ON INFO: All the 07s have the module except for the LMG (flexfuel) 5.3, the LC9 aluminum block 5.3 (believe that was ext/crew only) and the LY6 6.0L (not avail in reg cab). Same for the 2008 model year. ALSO, the only engine in 2009 model year to NOT use the fuel control module is the LY6 6.0L engine with VIN digit "K". Hope that helps.
On the 07's there are two different pump setups. One has a pump module at the back and one does not, if the truck does NOT have the module the swap will get a little uglier as the 6.2/6L80 needs that to run properly apparently. Daryn C might have more info on this?
UPDATE ON INFO: All the 07s have the module except for the LMG (flexfuel) 5.3, the LC9 aluminum block 5.3 (believe that was ext/crew only) and the LY6 6.0L (not avail in reg cab). Hope that helps.
