6.2 in the house and ready to swap
Old Mar 9, 2017 | 05:44 PM
capt_zman's Avatar
Default 6.2 in the house and ready to swap
6.2 is here. Swapping a 2010 L9H into a 2013 4.8 L20. 6.2 has everything included, harness, e38 ecu, o2 sensors and all accessories. My truck currently has the e38 with a 4l60.
Is there anything other than dropping in the new engine and using my current harness and ecu or do I need to use the 6.2 harness and ecu? I have hptuners and can modify the tune pretty quickly from a stock 2010 L9H or am I oversimplifying things?
Thanks
Old Mar 9, 2017 | 10:29 PM
Wolftrk99's Avatar
Shoukd be a drop in swap... use you harness and ecm, iirc the l20 has vvt but no dod, and the l9h is same way, the l9h harness should be set up for a 6l80
Old Mar 10, 2017 | 06:36 AM
capt_zman's Avatar
Yes u r correct. Both are VVT only and both are Flex Fuel.
Hopefully this will go off without any major problems.
Old Mar 23, 2017 | 02:31 PM
capt_zman's Avatar
Update:
6.2 is in and everything is running great so far. The 6.2 dropped in pretty easily. I used all of the accessories, sensors, ecu, and exhaust manifolds off of the 4.8 (since it was newer). The engine fired and ran pretty well with the stock 4.8 tune, but it really came to life with a stock 6.2 tune I modified. Just finished the MAF side of the tune and am now working on the speed density portion. It's has a couple of degrees of knock around 1200-1800 rpm at .24 to .72g, but I think it's do to being a mix of 87 and 93 in the tank. I'll try straight 93 next and then e85. If it continues, I'll take some spark out of it.
Holy crap what a difference in power. Now when I put some leg into it, I don't have to sit around and wait. Great upgrade so far.
Dyno scheduled for next week.
Old Jun 17, 2017 | 06:59 PM
Duramax27's Avatar
Registered User
Hey man, I'm looking for some insight, I have a 07 Tahoe flex fuel that I swapped in a 2009 non flex 6.2.i used the harness from the 6.2 and pcm. It's just turning over no start I'm am completely lost.
Old Jun 17, 2017 | 07:21 PM
FFDP's Avatar
Did you disabled the VATS system?
Are all the settings for various sensors correct for the parts you are using. Like the MAF curve, injectors, MAP sensor settings?
Old Jun 17, 2017 | 07:35 PM
Duramax27's Avatar
Registered User
Yeah everything was done by my local tuner, but he was explaining to me that since my truck is a flex fuel I would have to get a non flex pump and module for it to run but I just don't want to go out and start buying parts
Old Jun 25, 2017 | 03:29 PM
Tikiclub2's Avatar
Are y'all running 4l60e still, or swapping over the 6l80e? My understanding is that the latter trans has a computer that comes with it. I have an 07 Tahoe that could use the swap.
Old Oct 31, 2017 | 08:43 AM
capt_zman's Avatar
Yes, still running the 4l60e but thinking about the 6l80 speed with new gears. So far so good
Old Oct 31, 2017 | 10:34 PM
B00sted2007's Avatar
why didn’t you just keep your stock wiring harness and Ecu from the Tahoe? You could’ve swapped the other motor in and fired it right up! Flex fuel has nothing to do with the motor, except Injector size. You could’ve swapped your new motor in, swapped injectors out of your old motor into it, and been good to go. No sense in changing ecu and wiring harness. Of course you would want to have it performance tuned after the swap, but that would be it.
