6.2 good dyno tune numbers
I got my 2011 chevy Silverado dyno tuned today. It only has 650 miles on it and here is the mods below.... I Break all my vehicles in real hard after 200 miles and i always get good dyno results.
160 thermostat
Volant CAI
ARH 1 7/8 Longtube headers with cats into a Borla XR1 3.5 race muffler (straight thru) I put on myself dumped TILL TODAY! I just had ARH route the exhaust out the side in front of the right rear wheel with 2 stainless tips that are staggered. Let me tell you it looks good and sounds sick!!!!!!
all numbers are uncorrected and on a Mustang dyno. all dyno pulls were performed in 4th gear. if your worried about your stock driveshaft than change it cause i wasn't!!!
FIRST PULL BASELINE UNTUNED/UNCORRECTED 338 RWHP 366 Torque
3 PULLS LATER TUNED 362 RWHP AND 376 TORQUE
OF COURSE TORQUE MANAGEMENT AND ALL THE OTHER BS IS HISTORY. FIRMED UP THE SHIFTS, PART THROTTLE SHIFTS, AND SHIFT POINTS, REV LIMITER IS @ 6600 WHICH I TESTED DOING SOME FIRST GEAR BURNOUTS.
conclusion = BEAST for what it is and what it has!
160 thermostat
Volant CAI
I'm sure it is still much closer than 3rd though. I will get my truck dynotuned after my Kooks and 4.11s go in and am pondering the driveshaft myself. I have the big 1 piece aluminum one (but it is still a little shorter than a 2wd truck at least) and after seeing some of the posts here may upgrade it before then too.
Seeing these #s on a Mustang dyno has my hopes up.
Having the stock shaft balanced for higher speed may be enough, but I don't know for sure.
The factory balance is for your tire rating, so about 100mph.
If you end up running 120 on a dyno, it is a risk.
I had a nnbs 07 2wd xcab. It had a 96 inch one peice alum shaft. 6 inch diamater
I tried to dyno that truck but is started to shake pretty bad so I stopped.
I'd say that d/shaft would have looked like a skipping rope at 120.
