4WD alignment w belltech drop struts
Old 07-08-2013, 06:38 PM
Default 4WD alignment w belltech drop struts
I'm tired of my horrible turning radius with the MCG spindles and have decided to give the belltech drop struts a try and see how they work out. Reading through the instructions they state there is a possibility of the camber being out of OE spec without using 2degree upper control arm bushings to correct.
Those of you with 4wd and at 2 inches of drop do you know if they were able to nail the camber at OE for your or are they for sure going to be off and I need to order the upper control arm bushings. I want all the parts to do this once and right and be done with it and enjoy it.
Old 07-08-2013, 09:51 PM
AUTOT3K's Avatar
I'm 2wd and my camber adjust is almost maxed at 1" of belltech drop
An avalanche I did at work did the 2" and we used thebushings and it turned out perfect
Caster will always be more positive then spec but that's just a fact with lowering plus its good for higher speeds haha
So yes get the bushings
When I have to do my upper ball joints ill be doing those bushings at the same time
Old 07-08-2013, 10:05 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
Do the bushings. Otherwise your alignment will be "borderline" at best.
Old 07-08-2013, 10:40 PM
I ordered the struts from summit 191 to my door.
I went ahead and ordered belltech 4957 kit. It's the bushings and the alignment eccentrics figured if all I need is bushings then great because it's my luck to just order bushings and then need the alignment eccentrics on saturday at 3 in the afternoon and not be able to finish the truck.
Old 07-09-2013, 04:54 PM
FormerVendor
TheSuspensionSource's Avatar
Most cases you will only need the bushings. Extreme drops need the cam plates as well.
Old 07-09-2013, 10:59 PM
AUTOT3K's Avatar
What's the seperate part numbers for the bushings and plates not the kit
Old 07-10-2013, 10:33 AM
FormerVendor
Bushings (2 degree) - 4955
Cam Plates (1 degress) - 4951
06droppedcrew
11-17-2015 10:56 PM
Tydriver
45
10-23-2015 09:19 PM
Dezmo
09-09-2015 02:09 AM
xerox17
09-05-2015 01:23 PM
Quick Reply: 4WD alignment w belltech drop struts
