4WD alignment w belltech drop struts
Old Jul 8, 2013 | 06:38 PM
Default 4WD alignment w belltech drop struts
I'm tired of my horrible turning radius with the MCG spindles and have decided to give the belltech drop struts a try and see how they work out. Reading through the instructions they state there is a possibility of the camber being out of OE spec without using 2degree upper control arm bushings to correct.
Those of you with 4wd and at 2 inches of drop do you know if they were able to nail the camber at OE for your or are they for sure going to be off and I need to order the upper control arm bushings. I want all the parts to do this once and right and be done with it and enjoy it.
Old Jul 8, 2013 | 09:51 PM
AUTOT3K's Avatar
I'm 2wd and my camber adjust is almost maxed at 1" of belltech drop
An avalanche I did at work did the 2" and we used thebushings and it turned out perfect
Caster will always be more positive then spec but that's just a fact with lowering plus its good for higher speeds haha
So yes get the bushings
When I have to do my upper ball joints ill be doing those bushings at the same time
Old Jul 8, 2013 | 10:05 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Do the bushings. Otherwise your alignment will be "borderline" at best.
Old Jul 8, 2013 | 10:40 PM
I ordered the struts from summit 191 to my door.
I went ahead and ordered belltech 4957 kit. It's the bushings and the alignment eccentrics figured if all I need is bushings then great because it's my luck to just order bushings and then need the alignment eccentrics on saturday at 3 in the afternoon and not be able to finish the truck.
Old Jul 9, 2013 | 04:54 PM
TheSuspensionSource's Avatar
FormerVendor
Most cases you will only need the bushings. Extreme drops need the cam plates as well.
Old Jul 9, 2013 | 10:59 PM
AUTOT3K's Avatar
What's the seperate part numbers for the bushings and plates not the kit
Old Jul 10, 2013 | 10:33 AM
FormerVendor
Bushings (2 degree) - 4955
Cam Plates (1 degress) - 4951
06droppedcrew
Nov 17, 2015 10:56 PM
Tydriver
45
Oct 23, 2015 09:19 PM
Dezmo
Sep 9, 2015 02:09 AM
xerox17
Sep 5, 2015 01:23 PM
