4l60 to 6l80 swap
Old 04-12-2013, 11:03 AM
motohead911's Avatar
Thanks for the replies.
Like is said I am in the starting stages of getting everything. The reason I was looking at the 09 ECM with matching harness, is that both the 09 the my truck both have the LY5 motor. A difference is the trannies. Also, I have learned that there was an OS Change in 09 so my ECM would not work. I have a dealer that will flash a ECM with the 09 flash, if that is the way I go.
Iamkeniff: I Reread through your post where you detailed the swap you did, which is helped a lot. The problem I would have with a Denali flash is the motor is all wrong. Also, I have figured the BCM would be a pain, so I am also think of getting a corvette TCM flash to bypass the TU/TD function of the BCM.
Well I need to get the software plan figured out. Thank again for any more input.
Bob
Old 04-13-2013, 09:46 PM
iamkeniff's Avatar
the engine side of the ecm tune can be changed by the tuner
as for the corvette setup you need a tutd harness to make that work which i have sitting in my tool box. i wont be using it so if you want pm an we can discuss it.
yes the 07 an 08 use same OS style an the 09+ is different....yet there is no need to swap any of that if you do what i mentioned. plus itll save you money on buying an ecm you dont need
Old 04-13-2013, 09:55 PM
10 Second Truck Club
RS/SS 4.8's Avatar
Originally Posted by 2007chevy5.3l
Sweet! Now I know for my 6l90e swap
X2. I got nearly everything. Just need to get off my lazy *** n do it lol.
Old 04-13-2013, 09:58 PM
RS/SS 4.8's Avatar
Originally Posted by iamkeniff
the tcm cant shift fast enough using the tu/td feature. only reason for that feature is to select 3rd or 4th for towing or at the beginning of a roll race. my tcm tune does that for me so i dont have the desire to fool with the tu/td feature
Can u explain the roll racing part? How does that work? Is it set to downshift at certain rpm's, tp%, and does it hold that gear. That would be neat that way I can get my tuner to do somethin similar.
Old 04-14-2013, 09:50 AM
Iamkeniff, I just read your build and get it. Since I need to tune the truck anyways I am going to a new plan of attack. I am going to use an 07 or 08 Denali os and harness and have the tuner put my current engine data back in along with my current VIN. Now I just need two VINs one for the 2wd denali and a 2500 with similar option for the BCM and Cluster.
Old 04-14-2013, 09:59 AM
2007chevy5.3l's Avatar
Keep me/us posted. I'm sure you will have it swapped in and running before I get to mine
Old 04-14-2013, 01:29 PM
iamkeniff's Avatar
tutd is altered to select a gear at XX mph then hold it till the mph/rpm of my shift point. it works very well for me.
Old 04-16-2013, 02:05 PM
Iamkeniff,can you pm me a have a couple of questions about your swap.
Bumpers
11
03-04-2024 05:55 PM
Bluecollar Hotrods
03-13-2017 05:02 PM
Three6GMC
08-28-2015 07:56 AM
SloSVO
08-11-2015 07:33 PM
lo&sloSierra
07-19-2015 10:56 AM
Quick Reply: 4l60 to 6l80 swap
