4.11's???
Old 08-22-2017, 10:41 AM
Jonblarc7's Avatar
Default 4.11's???
This is probably a stupid question but is this a price for front and rear 4.11's. I thought they where a lot more expensive
1999-2008 Chevy 4wd GM 8.6" 8.25" IFS Master Install 4.11 Gear Pkg - Ron's Machining Service
With my 22 x 10" and 33" I think some gears would help pulling my boat tremendously, I have the 3.42 now. How much should an install run. I'm not sure if it's something I could do my self since I never done anything like that before.
Old 08-22-2017, 01:43 PM
madmann26's Avatar
Gears are cheap.
That is for the front and rear diffs.
If you have a 6spd, get 4.56s.
Old 08-22-2017, 01:53 PM
Jonblarc7's Avatar
you don't think 4.56s will be turning to high of an RPM at 75 with 33's even with the 6 speed.
I thought about 4.30's
Old 08-22-2017, 02:50 PM
madmann26's Avatar
Nope.
If anything it'll help as crazy as it sounds.
I estimate about 2500rpms in 6th with 4.56 gears and 33" tires at 65.
My 60e with a 29in tire and 4.11's turn about 2800 or so at 75.
Old 08-22-2017, 03:01 PM
FFDP's Avatar
If I did these calculations right using an online mph calculator here are the results.
Using the 6L80e with a 4.56 rear gear with 33in tires, a .667 6th gear ratio and a 1.1 transfer case ratio the rpms are roughly 2000-2100 at 65 mph.
Then it bumps up to around 2300ish at 75mph.
Old 08-22-2017, 03:05 PM
Jonblarc7's Avatar
Well that doesn't sound that bad. Pulling my boat in 5th around 65 I think I'm running right around 2400 rpms. With these 33's it wants to down shift to 4th at the smallest of hills.
Old 08-22-2017, 04:25 PM
Jonblarc7's Avatar
I was wrong 5 gear at 65 is 2000 RPMs now with 33's and 3.42's
Old 08-23-2017, 05:04 PM
madmann26's Avatar
It's a negligible difference.
Old 08-24-2017, 08:59 AM
BigKID's Avatar
Since you are concerned about 5th gear @ 65 mph for towing:
3.42 = ~1900 rpm
4.10 = ~2300 rpm
4.30 = ~2400 rpm
4.56 = ~2600 rpm
Same setup @ 75 in 6th for further comparison:
3.42 = ~1750 rpm
4.10 = ~2100 rpm
4.30 = ~2200 rpm
4.56 = ~2350 rpm
I have been considering 4.10s myself when I have to eventually open up the front differential for a rebuild.
Old 08-24-2017, 09:36 AM
Jonblarc7's Avatar
Thanks for that
I think I would rather have 4.30s since we do take my truck for family trips to the beach. So I do drive at 75-80 mph some. I'm just not sure if 150 RPM would make a difference in MPG. If it doesn't I'll just get 4.56
