2010 4.8 to 6.0 swap rcswb questions
Old Mar 22, 2012 | 11:03 PM
DCG76's Avatar
Default 2010 4.8 to 6.0 swap rcswb questions
Ok, i have searched awhile, here and other forums, all ive found is very old and incomplete answered questions. I plan on swapping a 6.0 into my 4.8 2010 silverado. I would rather use a 2007 and older 6.0, mainly cause cost is less. But my question is will these engines of that time period even work? If so is there a write up somewhere that someone can direct me to that i have over looked? or maybe someone can just enlighten me here, thanks alot.
Old Mar 23, 2012 | 06:45 PM
Chevy_Truck_Man's Avatar
I know it's illegal... no inspections ftw
Old Mar 23, 2012 | 07:48 PM
62nalide's Avatar
Old Mar 23, 2012 | 10:06 PM
Three6GMC's Avatar
All depends on how old. If its a 24x crank engine then no as your truck uses a 58x crank trigger and there isnt a conversion box for that. Only conversion box out right now is to run a 58x engine in a 24x crank truck. (99-07 classic) you can swap cranks out tho or have the crank trigger wheel swapped out to a 58x. Other then that won't work.
Old Mar 23, 2012 | 10:08 PM
silverado1ss89's Avatar
I'm doing the swap next week.. Should be pretty simple... My ly6 came out a vortex max.. So plug and play... If you get it from a van.. You have do some minor
Things
Old Mar 23, 2012 | 10:14 PM
Three6GMC's Avatar
Things
Yours is plug and play as you are using a newer 6.0 I think he is talking about swapping out a older lq4/lq9 6.0 into his newer truck. Which I that case not plug and play.
Old Mar 23, 2012 | 10:15 PM
62nalide's Avatar
Things
Not the same swap the ly6 is 07 and up he asked for a earlier 6liter as in lq4 lq9
Old Mar 23, 2012 | 10:18 PM
62nalide's Avatar
Oopsy u beat me to it^^^^^
Old Mar 23, 2012 | 11:31 PM
DCG76's Avatar
Idk, it's frustrating.. I can find older 6.8's cheap(pre 07). I wonder what a 58x 4.8 crank in a 6.0 would do? Haha
Old Mar 23, 2012 | 11:32 PM
DCG76's Avatar
Fat thumbs meant 6.0 not 6.8
