2/4 drop on NNBS question
14 Second Truck Club
I am still wondering whether I will need to go the 5" in the back or not. When I installed the 2" drop shackles in the rear the front was still 1" lower so I went another inch and it sets level now with the 0/3 lowering I have done.
So when I lower the front 2" Saturday it only makes sense that I will need to lower the back another 2" to maintain a level stance.
And like you mentioned it could be a little different being that yours is 4x4 and then also there could be a slight difference being 2007 and 2010.
Ended up dropping the back 5"...doing 2" inches in the front now and we'll see if the stance is right at 2/5...
I hope so because the 305s look bad *** in the back so it would suck to have to raise the back up an inch...
Well Shane B you were exactly right!
Got it all set up at 2/5 and the back was about 3/4" lower than the front so we put the factory block back in over the rear axle and it's perfect. There is just a slight rake to it now and the 305s look a lot more at home.
I must say I really like the appearance with it 2/4.
