18's to 16's! Will it help?
Old Apr 14, 2009 | 07:10 PM
VMax's Avatar
Default 18's to 16's! Will it help?
I am running the chevy factory 18's with the factory tires. If i go to a 16 inch wheel and get the same size tires, 265/65/18 to 285/70/16. Since there is more rubber will it weigh more or less since there is less wheel?
Old Apr 14, 2009 | 07:53 PM
MonteCarlo31's Avatar
I don't think it will make a difference. Keep what ya got. I don't believe 16s will fit either but if you want to swap I'll trade ya my 90% 295/70R17s on stock 17" rims.
Old Apr 14, 2009 | 08:28 PM
vortec-dude's Avatar
I had factory 18s with a 29"tire and went to factory 17s with 30-1/2", and my truck felt much lighter and faster with the smaller tire. So what i would recomend is getting a smaller tire.
Old Apr 15, 2009 | 04:37 AM
VMax's Avatar
Man i was hoping they would fit, and i figured they would stay the same too. But others have said it would help
Old Apr 15, 2009 | 04:43 AM
GMCtrk's Avatar
I lost ALOT going from stock steel 255/70/16 to aluminum escalades 285/60/18
Old Apr 15, 2009 | 04:49 AM
VMax's Avatar
so you went up 1.5 inch in tire diameter and 2 inches in wheel. See i just wonder if going down two inches and staying the same size in tire diameter would help or stay the same
Old Apr 15, 2009 | 09:06 AM
NGA PLZ's Avatar
If you have rear disc brakes than they may not fit. Just look for the lightest possible wheel. Centerline makes a 22 lbs 18".
Old Apr 15, 2009 | 06:46 PM
VMax's Avatar
no rear disc's. i have drums. and ok thanks i will check that out. and is 22 lbs good or bad
Old Apr 15, 2009 | 06:48 PM
GMCtrk's Avatar
my escalades weigh 28's each. I want to switch to a lightweight 18
