08 Silverado performance
Old Aug 13, 2013 | 08:24 AM
swift700's Avatar
A tune will not take care of low-end throttle response. The 4.8 makes no torque down low. A higher stall converter will skip right over that low end and get into your power band immediately.
However though, to make the power you want, you'll need to spend some money. Nitrous or boost will get you there. I'd find a good used turbo setup.
Old Aug 13, 2013 | 05:34 PM
slammedsilvy's Avatar
There are quite a few converters under $1,000. Circle D I know for sure has one, Yank likely will also.
Old Aug 24, 2013 | 09:42 PM
silverokie19's Avatar
Registered User
I've decided to get the long tubes and ORY first, and then a good custom tune locally around November. Currently I have 32" diameter tires and 3.23 gears. How much would getting 3.73 or even 4.10 gears benefit performance? They're online for around $200. How difficult is install?
Old Aug 24, 2013 | 10:22 PM
4.10 would give you a completely different truck. The actual labor of installing gears isn't difficult, but you have to know what you're doing to install them correctly and have them last.
Old Aug 24, 2013 | 10:34 PM
AUTOT3K's Avatar
by the time you bought the tools to install the gears properly, not to mention a press...you'd be better off to have them installed with a warranty. its not to hard to do, kinda time consuming and if your not sure what rotational torque is, bearing preload, case spread, backlash or reading a pattern means...you could end up spending double when you wreck the new gears and have to have them re done
Old Aug 25, 2013 | 09:49 AM
mdwatts11's Avatar
You may want to wait and do the LT/ORY setup until you are ready to tune. You will get a check engine light and it might affect the drivability of your truck.
Gears are cheap, but the install is the pain. It can cost up to $1000 to pay someone to do it. If you have any kind of mechanical experience, you can follow the how-to on here, however you do need additional tools you may not have. If you are staying naturally aspirated, a set of 4.10s will really wake it up.
Old Aug 25, 2013 | 10:53 AM
silverado6.2's Avatar
I think someone else mentioned it already, but If money is tight and you want 400 hp then nitrous is the only way that I know of to get there cheap. Gears will make you quicker, a stall will help too but whatever hp you have now will not change.
Old Aug 25, 2013 | 10:12 PM
Registered User
How bad would going up in gear size kill gas mileage?
Old Aug 25, 2013 | 10:16 PM
AUTOT3K's Avatar
my city mileage got better and when it came to the highway I just sped a touch less and that compensated for it
Old Aug 26, 2013 | 11:20 AM
mongooseboy000's Avatar
Originally Posted by slammedsilvy
Sell the throttle body spacer, try to recoup your money. If your flowmaster is a chambered muffler, you're hurting your performance.
Long tubes and y pipe are great investments. You only have one cam, but a cam with specs ground to your application will greatly benefit you. Forgot about a programmer, get a custom tune from someone local, preferably in person or on the dyno.
A tune will give you the biggest improvement in driving characteristics. Do you plan to do all of this at once, or piece by piece over a period of time? If all at once, get the tune afterwards so the tune can take into consideration off the the other mods. If piece by piece, I would say tune first to wake the truck up, then add to it and retune for the mods down the road.
Make a plan, and stick to it. I'd read a lot before spending any money. Find out what works, where you want to be, what it will take to get there, and stick to it, otherwise you can buy many parts now that won't benefit your goal later down the road.
perfect, i agree. i myself did allot of thinking before dumping money into my truck. i think slammedsilvy did as well. we have 4.8 so its a tough choice for us. either swap it or stick with it. i went turbo as that will land the most bang for ur buck and 4.8's love boost. but follow those rules and u will be good. also
5.3lSilverado
25
Aug 29, 2016 12:48 AM
B.love18
Sep 21, 2015 08:31 PM
signguy62
Sep 20, 2015 02:05 PM
cbhedrick
Jul 20, 2015 10:12 PM
Deceptarado
Jul 8, 2015 05:24 PM
