08 denali awd front wheel hub
Old Aug 20, 2009 | 08:13 PM
wot_denali's Avatar
Default 08 denali awd front wheel hub
I am going to replace the factory front axle hub with the timken products but i am still not sure which timken part number will fit to my application ,i need help
Old Aug 21, 2009 | 02:52 PM
MonteCarlo31's Avatar
I used NAPAs complete assembly. working well with 55K miles on it running 33.5x11.5x17s in the muck and mud almost daily in a heavier truck (less hp but more weight). I'd try the NAPA, if I remember when I looked at the bearing pressed in there it was stamped timken.
Old Aug 21, 2009 | 04:52 PM
bdubb's Avatar
Just curious, but what is your reason for this?
Old Aug 26, 2009 | 12:16 PM
wot_denali's Avatar
I am getting abs + traction control wile turning ,i took the car to dealer many times at the end they told me that the axle hub need to be change the car ran up to today more than 125k miles the oem axle for 2 costs more than $700 so that i need to look for a good aftermarket axle hub.
Old Aug 26, 2009 | 12:26 PM
Yep all you need is the hub assembly. Should be around 160 dollars ea at NAPA. Like I've said, I don't have the same power you do but I'm running a truck that is probably 800 lbs heavier and tires that are easy x2 more weight then the OE tires on the Denali and my NAPAs have lasted longer then the OEs.
Old Aug 27, 2009 | 11:12 AM
wot_denali's Avatar
What do you mean by napa ,is it an aftermarket company or what ineed a part number or a link to buy this item.
Old Aug 27, 2009 | 12:31 PM
Zick's Avatar
http://www.napaonline.com/
It a chain auto parts store like Autozone.
gnasty1521
35
Nov 19, 2015 11:42 PM
maxspeed05V
Sep 9, 2015 11:36 AM
chacho44
Aug 3, 2015 04:07 PM
Denali man
Jul 19, 2015 03:52 PM
