07 VMAX oil cooler line replacement
Old Feb 27, 2016 | 02:01 PM
omalley1537's Avatar
Default 07 VMAX oil cooler line replacement
Hello all,
As is common, my original oil cooler lines are leaking. I have a replacement set (GM) and have read the write up regarding pulling the front driveshaft, skid pan(s) etc and not having to undo the motor mount or diff. This was for a pre-NNBS truck so I was wondering if it's essentially the same for mine (07 NNBS VMAX 4x4)?
Also, does the oil have to be drained first? I would think most would be in the pan but I don't want to drain all my oil as soon as I pull the cooler line block...if oil needs to be empty I'll wait since I just changed it about 500 miles ago (don't want to waste it with what they get for synthetic...)
Thanks!
Old Feb 27, 2016 | 02:16 PM
FFDP's Avatar
Should be very similar and no you do not have to drain the oil.
Old Feb 27, 2016 | 02:27 PM
Thanks!
blackedoutchevy22
Sep 2, 2018 03:17 PM
Joevc
Feb 1, 2016 08:28 AM
Gadgetized
Jan 31, 2016 11:25 AM
zblee
Jan 29, 2016 08:01 PM
madmann26
Jan 28, 2016 10:07 PM
