07 Avalanche Sunroof leaks
Old Mar 11, 2010 | 07:02 PM
flynn78us's Avatar
Default 07 Avalanche Sunroof leaks
I got in my new/used avalanche and when I make turns a little drop of water forms by my overhead console. Where the lights and on-star stuff are, it there a little pan area for the sunroof drain there that might be clogged? Anyone else have this problem?
Old Mar 11, 2010 | 07:20 PM
DOA's Avatar
DOA
Don't open your sunroof in the rain.
Old Mar 11, 2010 | 07:44 PM
flynn78us's Avatar
ha ha......any real insight would be helpfull
Old Mar 11, 2010 | 07:45 PM
flynn78us's Avatar
Do you have a pic of your truck with the drop?
Old Mar 12, 2010 | 12:28 AM
Mrgoodwrench3's Avatar
Do a visual check of the weather strip with it open and closed. Look for any deformation. Most times the glass needs to be aligned. This is a involved job. May require removal of the headliner. Although the Avalanche is easier because you can remove the headliner out the back with the window removed.
Old Apr 1, 2010 | 04:50 PM
tallbluslpr's Avatar
Hey dont know if you have resolved the problem yet but I have seen it several times. The sun roof is not designed to seal out water there is a tray between the headliner and the roof of the vehicle water runs in around window hits the tray and drains via draintubes running down the front "A" post in front of the door and draining under the truck. Open sunroof find tray and locate drain tubes use compressed air to unclog there should be at least two of them. Im very confident this is ur problem I have seen it several times hope this helps
Avalanche2002
Nov 30, 2015 07:31 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
FormulaZR
Sep 14, 2015 05:23 PM
726.0chevelle
Sep 12, 2015 09:24 AM
