07 2500 no throttle control
Old May 27, 2025 | 11:26 AM
thebrain's Avatar
Default 07 2500 no throttle control
07 Hummer H2 no throttle control
This is basicley a Chevy 2500 w/ LQ4.
I just backed the H2 up a little I think it was idel throttle to back up just after putting in gear an letting off brake.
Throttle was working fine a few weeks ago.Now I don’t have throttleedit I don't drive this vehical much so I dissconnect the battery usaley I dissconnect the positive but this time I dissconnected the negative.
doe's this sound like I need to relearn the throttle position sensor? if yes a video or the procedure would be a big help
please advise
Old May 27, 2025 | 01:30 PM
RDF1's Avatar
DuNnO
5 Year Member
Did you read for any codes?
Old May 27, 2025 | 02:18 PM
thebrain's Avatar
have yet to read for codes.I do not have a code reader, considering purchasing this an get 3rd party software Torque blue toothed to a tablet.
https://www.amazon.com/MMOBIEL-OBD2-Scanner-Bluetooth-Android/dp/B0B9YPPTLC/ref=sr_1_49?crid=GYS90TFT0LQT&dib=eyJ2IjoiMSJ9.aynwsg1Pe3YQP4ScGZ-gKkcgV2-cAtlnzgLEUroi87Ntm0keWvYJD4TW-ho30qLIQkYSQXI1AHDJwAcYFBPfXnPgzS_A4iFZqFFYPOS_cAFgSJrhh10quTBZRngnYcnNY3BZUU3xCpJsuYs8Ep2-ng.b3Ugtzo07OcrBkhn0Cip_t4Wr61YTk8Gv9M1uKy2LAk&dib_tag=se&keywords=obd%2B2%2Bscanner%2Bdiagnostic%2Btool&qid=1748372660&sprefix=OBD%40%2Caps%2C168&sr=8-49&xpid=JcjqznIysN13_&th=1 https://www.amazon.com/MMOBIEL-OBD2-Scanner-Bluetooth-Android/dp/B0B9YPPTLC/ref=sr_1_49?crid=GYS90TFT0LQT&dib=eyJ2IjoiMSJ9.aynwsg1Pe3YQP4ScGZ-gKkcgV2-cAtlnzgLEUroi87Ntm0keWvYJD4TW-ho30qLIQkYSQXI1AHDJwAcYFBPfXnPgzS_A4iFZqFFYPOS_cAFgSJrhh10quTBZRngnYcnNY3BZUU3xCpJsuYs8Ep2-ng.b3Ugtzo07OcrBkhn0Cip_t4Wr61YTk8Gv9M1uKy2LAk&dib_tag=se&keywords=obd%2B2%2Bscanner%2Bdiagnostic%2Btool&qid=1748372660&sprefix=OBD%40%2Caps%2C168&sr=8-49&xpid=JcjqznIysN13_&th=1
I don’t drive this vehical much at all an always completely disconnect the battery an place on a solar trickle charger.
Sometimes I just disconnect the positive then reconnect when I want to move vehical, I just move it around the backyard. I have driven it on the road just to see how she drives, but haven't register it plan to when I relocate to differnt State.
This time I only disconnected the negative the positive was left connected.
could the batterys negative being dissconnected have confussed the computer? thanks
Old May 27, 2025 | 02:22 PM
RDF1's Avatar
DuNnO
5 Year Member
It doesnt get confused.
If something with the pedal, Tac module, throttle body, or PCM isnt happy the pedal wont work.
So have to start looking for the problem.
A scanner will be your only friend here.
I dont think that bluetooth dongle will be able to read the TPS/APP voltages.
Old May 27, 2025 | 05:19 PM
RB04Av's Avatar
5 Year Member
It does. Doesn't show it as "voltage", as such; butt does show it as a "percentage". Can't recall whether it can show gas pedal position butt I kinda think it can; again, in %.
No. Either the ECM gets power or it doesn't. Doesn't care, doesn't know, can't even tell, which cable was disconnected.
Old May 30, 2025 | 06:47 PM
thebrain's Avatar
how about this el cheapo scanner
Amazon Amazon
thanks
maybe the above scanner would be better? also can just dissconnect the computer an reconnect in hopes of cleaning off the connections? also dissconnect an reconnect the throttle body harness an spary electronic cleaner in the plugs.
sorry to be such a newb I don't even know where the computer is mounted on the hummer thanks for advise
Old May 30, 2025 | 11:11 PM
RDF1's Avatar
DuNnO
5 Year Member
I doubt that one would give you nice live data.
Ive never used those type of scanners.
I use my laptop or an Autel
https://a.co/d/e69MRTu
Old May 31, 2025 | 02:11 PM
thebrain's Avatar
hopefully I can read some codes an find whats broke. also can just dissconnect the computer an reconnect in hopes of cleaning off the connections? also dissconnect an reconnect the throttle body harness an spary electronic cleaner in the plugs.thanks to be continued when I get the scanner in a few days.
Old Jun 2, 2025 | 08:03 AM
MikeGyver's Avatar
"and"
Old Jun 2, 2025 | 02:19 PM
thebrain's Avatar
I'm suposed to recieve the el cheapo scanner mid week will report back then. hope it's not to complicated for me.any tips on how to operate this cheap scanner. thanks
