07-08 4L60e to 6L80e swap
Old Nov 27, 2010 | 08:58 AM
  #91
iamkeniff's Avatar
well when you do decide to swap to a AWD setup post up a thread. ill never go through the labor of it but the 4wd crowd may want to do it. i dont see a problem with taking a 4wd and making it awd from a denali with the 6spd. if i had extra money id buy a 4wd just to try it.
Old Nov 27, 2010 | 11:11 AM
  #92
pewterliftedz's Avatar
oic. so the new trucks have a plug on the starter/
thanks for the info niff..
Old Nov 27, 2010 | 11:33 AM
  #93
iamkeniff's Avatar
im guessing the 09+ does...the harness i bought is for Skipperdaddys' truck. he used his vin to get me the harness/part number. those few little things i pointed out is pretty simple stuff. now if so happens i have to repin something ill post it up. im going to try an get a few things done tonight and bring my driveshaft to work to take the slip yoke off and get the new one installed so i hope. im going to make a carrier bearing bracket adapter plate just incase i have to move my front shaft back.
Old Nov 27, 2010 | 07:17 PM
  #94
skipperdaddy's Avatar
Been lookin too... cant find any deep or finned pans yet... tru cool keeps mine cool enuf for now..
Old Nov 27, 2010 | 08:27 PM
  #95
iamkeniff's Avatar
poo
Old Nov 28, 2010 | 07:39 AM
  #96
iamkeniff's Avatar
21153 is the u-joint part number i used on the slip yoke to front driveshaft. i also
used it on the rear driveshaft to the pinion yoke bc my truck has 1350 u-joints but the 2 peice i put it is a 1330 u-joint. the part number i have listed is a "conversion u-joint" for the 1330 to 1350. i will updrade to a 1350 driveshaft after everything is worked out. i may do that before i do the new crossmember
Old Nov 28, 2010 | 05:21 PM
  #97
Really good info niff... great detail with part numbers and all... great job man!
Old Nov 28, 2010 | 06:21 PM
  #98
iamkeniff's Avatar
thanks man. im trying to make it as easy as possible for the next person.
i have my carrier mount moved forward like it needs to be (maybe a little too much) but its just got to get me to MadMans so he can build the carrier bearing bracket.
still waiting on the Dealer parts
Dip stick tube
Shifter bracket
Retune
Old Nov 30, 2010 | 05:56 AM
  #99
iamkeniff's Avatar
ill have my parts today just wont have to install them thanks to the rain and im working late today. thanks to a wonderful bearing thats going out on a main support in the crane. it's going to be a full 12hr day i think if not more.
being that i have a 2 peice dshaft, i dont feel i have a problem with it being shorter. i do not like how it wobbles a little so what im going to do is have the driveshaft shop look at it, and possibly just make me a new driveshaft to make it not wobble. that may be the worst part of this swap. ill keep it updated once i get word from the driveshaft shop
Old Nov 30, 2010 | 03:21 PM
  #100
forget the crane!!! go home and work on the truck!!!!
