Yukon XL Denali 390 Turbo
Do you guys know if the 2005 xl Denali came with the 80e? Looking at purchasing 2005 Yukon xl Denali. I have a bad a$$ 390 fully built and looking to put a 76mm turbo on it. In your opinion should I stick with trying to find 2500 Suburban with all the beefy stuff on it or do you think the Denali will be ok? I really hope the 05 has an 80e in it, that would help a lot!! Not looking to go crazy hp numbers, settling around the 600hp mark. Another question would a built 4l60 around the 600 mark last?? Thanks!!
Plus the Yukon Denali will have the undesirable Borg Warner AWD Tcase , it doesn't react well to big power I've been told , kinda "bucks " around when launched , the NVG 149 in the sierra Denali is the AWD case to have
The 80e swap is straightforward and inexpensive. I would ask the purposebof the vehicle before suggesting a 2500. If you plan to tow then the 2500 is a much better choice of the frame and suspension. Trans and rear will be larger and stronger, but if this is just a cruiser/racer then the lighter 1500 is a better choice.
I have a 2001 2500hd extended cab with a mid mount 60mm turbo. I love the truck and that is what the 390 with bigger turbo was going to go into "originally".. Then the fact that I have two kids plus wife and we usually are towing a boat 5,000lbs i figured before I do this swap what would be a better ride for the family for the next 5-10 years. Now i'm in the middle of trying to get a 2500 Suburban but came across a really good looking and comfy Denali XL????
