Would you buy this engine?
Old Nov 23, 2007 | 02:27 PM
KevinF56's Avatar
Default Would you buy this engine?
so on car-part there is a 2003 LQ4 for sale that is very close to me. thing is it has 125,000 miles on it. i talked to the guy at the salvage yard and he said each cylinder has at least 185 lbs of compression. they tested it. they want $600 for it. would you buy it?
Old Nov 23, 2007 | 02:29 PM
truckmann's Avatar
Doesn't sound like a bad deal to me.
TXsilverado's Avatar
i would. my motor has 115k around now and im adding heads and 150 shot with no doubts.
Old Nov 23, 2007 | 02:34 PM
KevinF56's Avatar
say i buy it. would it be worth opening it up and taking the heads off, etc, or should i just leave it and toss it in my truck? if i bought it i'd be putting in a cam, most likely something in the 224/224 range.
Old Nov 23, 2007 | 02:46 PM
Derek @ EDO's Avatar
FormerVendor
GRAB IT!
For cam choice i would look into the 226/226 range with a Yank SS3600
I would verify the pressure.
The most i would do is put an LS2 timing chain in it with some ARP rod bolts. I would do that all while swapping the cam
Contact SDPC for a cam install kit.
If you do decide to pull the heads be sure to order some new head gaskets at the same time as the cam stuff to save on shipping!
Old Nov 23, 2007 | 02:47 PM
truckmann's Avatar
I'd pull the heads off and take a look just for piece of mind. A lot easier to deal with while not in a truck. Isn't that on the small side for a 6.0L cam?
Old Nov 23, 2007 | 02:52 PM
KevinF56's Avatar
Originally Posted by Derek @ EDO
GRAB IT!
The most i would do is put an LS2 timing chain in it with some ARP rod bolts. I would do that all while doing the cam
to tell you the truth i think i'm going to go with that Yank SS3600 because my TT3000 is too small, even with my stock cam. 226/226 might be fun. i'm sure i could DD it. hmm....maybe i'll think about picking this motor up.
Old Nov 23, 2007 | 02:59 PM
FormerVendor
You could def. DD it, no questions asked. I drive mine everyday.
Go to the track run 11's drive back and get 18MPG* doing it (not the racing part lol)
The ss3600 is pretty damn tight UNTIL you floor it!
Old Nov 23, 2007 | 03:23 PM
KevinF56's Avatar
what year was it that the LQ4s and LQ9s had the same connecting rods? was it 2004?
Old Nov 23, 2007 | 04:59 PM
Tootall's Avatar
it was 04 and up,
KB has a 230/228 cam . . . I'd get a bigger cam for sure!
