The worst PITA install ever
Old Jul 19, 2005 | 08:44 PM
02sierraz71_5.3's Avatar
Default The worst PITA install ever
This is the most hated thing I have ever installed on a vehicle. I have to replace the turn signal switch, so I figured 2 hours at the most started at 6pm. After getting the dash and column covers off, took off turn signal assembly and noticed wires snaked way back towards the fire wall. So had to take off bottom part of dash and heavy metal plate under steering column. Start fishing wires and notice they are wrapped all over and one goes around the comlumn and back to where my hand wont fit. So after messing with trying to free the "quick disconnects" its getting dim. Now I need a flash light find the mag light look around and notice a black cat walks right behind me and sits in the middle of the parking lot staring at me like bad luck just laughing saying your not gonna get out of this easy mmmuuuuuhhhhaaaaaa
so I commence to throw rocks at the black cat. Time to go back to work the flash light is very dim and flickering go get batteries and the old ones have all busted open and are stuck start beating on it and finally get one out now the others are stuck and wont come out and its to mangled to put the cap on **** it throw it away.
After 2 hours in 103 degree humidity Im soaked hatin life the dash is pulled apart wires are every were and I go to lock up the truck and notice the windows are down and of course they are powered through the module it just took me 2 hours to figure out how to disconnect. Im just hopping it doesnt rain.
I could have the swapped heads easier than this
edit:now its thundering outside time for round two
edit:in the rain
Old Jul 19, 2005 | 08:58 PM
shandy294's Avatar
I dread the idea of doing any work to/inside a modern steering column. I replaced a turn signal canceller in a 77 Monarch but that was easy. Good luck!
Old Jul 19, 2005 | 09:27 PM
Dude that sux. Hope things work out for you.
Old Jul 19, 2005 | 09:39 PM
XLR8NSS's Avatar
Adkoonerstrator
Holy crap man.
If my signal switch ever goes bad I'm thinking it will stay bad.
Old Jul 19, 2005 | 10:42 PM
Originally Posted by XLR8NSS
Holy crap man.
unfortunately it takes the brake lights with it
and now its gonna rain all night and Ive got towls closed in the door covering the open window
I know its that damn black cat
I hate cats
Old Jul 20, 2005 | 12:07 AM
goshawk23's Avatar
Truck addict
Holy crap man.
much like my fuel sending(level) switch or what ever it is, it can bounce all day, i don't mind feeding it vs changing it.
Old Jul 20, 2005 | 03:15 AM
TXsilverado's Avatar
if anyone in the houston area ever needs steering column work pm me.
Old Jul 24, 2005 | 11:53 PM
bigredexpress99's Avatar
I had to do exactly the same thing, only R&R 3 times in 2 weeks. First time was because something shorted out inside of switch causing turn signal to stay on, and is was smoking lke crazy, second time, the wipers ended up going out and I only had 1 speed - HIGH. Then, the damn cruise control wouldnt work on the third one. I'm on my fourth and hopefully final one now. I am the PRO at removing those things, I can get it done in 30 mins from beginning to end now! And those switches arent cheap, thank god for the Wyotech Student Discount at the dealership, 140 freakin dollars, luckily, only had to pay once!
Good luck with that!!
Old Jul 25, 2005 | 12:29 AM
Kano's Avatar
edit:in the rain
F. cats
Ill bring the boys over next time you work on something
damn I didnt know it was that bad
funny post though
Old Jul 25, 2005 | 12:48 AM
PappyDan's Avatar
Tribe Shaman
ok here is what you do.
1. find the black cat, soak it's tail in gas, light it and send the kitty on it's way howling.
2. get your old lady's bra, pantyhose's and a beer ( at least a 12 pack ice cold )
strip down to your bvd's, put your old lady's pantyhose on your head, hold the bra in your left hand and the beer in your right, now dance around in front of your house singing GET ER DONE THE RAIN IS NO FUN.
3. let your old lady video this so we can have a good laugh
4. when the cops show up because the neighbors called it in RUN LIKE HELL.
