Wiring in turn signal mirrors
Old May 19, 2007 | 04:20 PM
tb8100's Avatar
Default Wiring in turn signal mirrors
Got an '03 GMC 1500HD with heated power mirrors, but no signals. Installed the '06-up camper mirrors, but I need to be able to wire in the heat and signal. Do I reuse the plugs off my old mirrors so I can plug into the door for the heat and power adjustments and then tie into the turn signal wire under the dash? I tried searching on this and found very limited info... Any help would be greatly appreciated!
Old May 20, 2007 | 11:29 PM
CashDudeHomie's Avatar
Should be just plug and play on 03 and up. Did you test them out yet?
Old May 29, 2007 | 11:29 PM
tb8100's Avatar
Plugged them in....now none of my switches work on my driver door and my a/c won't come on either... The signal works on the PS though! lol
Old May 30, 2007 | 02:32 AM
Oh sh*t, I should have read closer. They changed the mirrors in 06 so if you're putting 06 mirrors on an 03, you'll probably have to make a custom wire harness to get everything working properly. I hope you get it done without much trouble
Corvette454l88
Sep 1, 2016 01:24 AM
Y2KLimited
Dec 5, 2015 09:57 AM
03regcab sierra
20
Aug 3, 2015 12:11 AM
Ketis
Jul 23, 2015 12:37 PM
atxlt
Jul 20, 2015 11:06 PM
