Wiring in turn signal mirrors
Got an '03 GMC 1500HD with heated power mirrors, but no signals. Installed the '06-up camper mirrors, but I need to be able to wire in the heat and signal. Do I reuse the plugs off my old mirrors so I can plug into the door for the heat and power adjustments and then tie into the turn signal wire under the dash? I tried searching on this and found very limited info... Any help would be greatly appreciated!
Oh sh*t, I should have read closer. They changed the mirrors in 06 so if you're putting 06 mirrors on an 03, you'll probably have to make a custom wire harness to get everything working properly. I hope you get it done without much trouble
Corvette454l88
Sep 1, 2016 01:24 AM
03regcab sierra
20
Aug 3, 2015 12:11 AM
atxlt
Jul 20, 2015 11:06 PM
