Wiring Gauges
Old Feb 7, 2005 | 12:43 PM
ceomall's Avatar
Default Wiring Gauges
I have a few gauges to wire up and was wondering what is the easiest and also what is the best way to tap into switched power? Are there accessory circuits in the 2001 1500 interior fuse box I can tap off?
I know pretty much nothing about electrical stuff, so pictures and simple instructions would be appreciated.
Also, any recommendations on a good book (for wiring)?
Thanks,
Chris
Old Feb 7, 2005 | 05:53 PM
KeukaZ71's Avatar
i would get a light tester first. it can help you determine what polarity the wires are, neg or pos.
i like to tap into wires that are only positive when the ignition key is on.
Old Feb 7, 2005 | 06:58 PM
SnakeOiler's Avatar
Depending on your truck options, you could use your relay center (to the right of your parking brake. I've used it for constant and switched power, ground, etc.: https://ls1tech.com/forums/showpost....99&postcount=3
You need metripak 280 series connectors or any generic connector that would fit on those blades.
You can also possibly find empty connectors in you lefthand I/P fuse box.
Texas5.3_1251
Mar 5, 2016 08:10 PM
kalikid06
20
Oct 13, 2015 07:37 AM
kalikid06
Sep 13, 2015 05:48 PM
97gmc
22
Sep 8, 2015 10:56 PM
muncie21
Sep 7, 2015 09:55 PM
