wire harness question
Old Oct 4, 2010 | 05:31 PM
LS1CMR's Avatar
Default wire harness question
can i put a front harness from an 06 silverado that has e-fans and foglights on my 03 truck that doesnt have neither?, i have everything for the foglamps except the harness, and i want to put e-fans on my truck too. any suggestions?
Old Oct 6, 2010 | 05:08 PM
budhayes3's Avatar
PT's Slowest Truck
Not 100% sure, but you can get the fog lamps as a kit from GM so I'm assuming that the wiring is already there or the kit comes with a sub-harness, and guys have gotten the harness for the factory efans separately and wired it in, I'm sure that there's a part number floating around one of the GM sections...
Old Oct 7, 2010 | 04:42 PM
SnakeOiler's Avatar
you'll have to check the pinouts on the green connector sub assembly to see if they are the same between 2003 and 2006. If they are the same, then I say use it.
D1SCSS
Jan 25, 2016 10:14 PM
TimDave217
Aug 24, 2015 04:38 PM
USMCvet0311
Aug 1, 2015 07:45 AM
vortecyota
Jul 23, 2015 08:26 PM
