wiper sprayer keeps getting plugged
Old Dec 6, 2007 | 09:49 AM
awesomeame's Avatar
Default wiper sprayer keeps getting plugged
2002 silverado
the driver's side wiper sprayer keeps getting plugged up, not letting any washer fluid out. i'll spray some alcohol into the tip, let it melt the ice, and then everything works fine. but it's just a matter of time before it gets plugged up again with this cold weather! how do i fix this situation!!??? driving me nuts
--matt
Old Dec 6, 2007 | 11:25 AM
budhayes3's Avatar
PT's Slowest Truck
Is your washer fluid diluted with water? I use straight washer fluid this time of year...pretty much most of the time. If your washer jug is full, I guess you could always pull the washer pump out of it and try to drain it out...be careful not to break the pump.
Old Dec 7, 2007 | 05:23 AM
awesomeame's Avatar
nah i've always used proper washer fluid. the passanger side always seems to work fine. only the tip is getting plugged up, but the passanger side doesn't. ((shrugs))
--matt
Old Dec 10, 2007 | 08:15 PM
budhayes3's Avatar
PT's Slowest Truck
Is the hose kinked, or maybe some wax stuck in the end of the nozzle?
Old Dec 10, 2007 | 08:51 PM
nick993's Avatar
yeah just a little bit of air through the tube. a little, or you will blow the connection off. unhook the hose and blow through the hood cowl side.
twake_410
Apr 14, 2016 09:58 PM
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
KleanKustoms
Sep 30, 2015 05:07 PM
