wierd motor noise vid inside
Old 06-10-2007, 09:38 PM
SimpleManLance's Avatar
Default wierd motor noise vid inside
i got this wierd noise coming from the drivers side. it sounds like from the valvetrain. i pulled off the valve cover, everything looks good. nothing i seen looked broke.
it only makes this noise from 2-3000 RPMs
anyone got any ideas on what this noise is?
http://s2.photobucket.com/albums/y39...t=P1010120.flv
the videos not the best because it came off my digital camara.
Old 06-10-2007, 09:40 PM
ReSpAwN DeMoN's Avatar
Are you talking about that almost sorta kinda clicking sound when you finish with each rev?
Old 06-10-2007, 09:41 PM
yup the flutter kind of noise when i rev it up and then let the motor come back down.
the unnormal valvetrain noise
Old 06-10-2007, 09:42 PM
FormerVendor
Derek @ EDO's Avatar
sounds like a loose rocker,check all your rocker bolts and make sure they are torqued down to 22ft lbs, i think thats the torque spec. you might want to double check.
Old 06-10-2007, 09:45 PM
oh yeah i forgot to mention that we did check them. not with a tq wrench because we didn't have one but there all tight.
Old 06-10-2007, 09:50 PM
FormerVendor
Possible bent pushrod? It could be an exhaust leak as well.
Old 06-11-2007, 06:00 PM
anyone else with ideas?
i will try and get a better video of it..
Old 06-15-2007, 08:26 PM
TTT
just got done pulling the push rods, all of them are straight, everything under the valve cover looks good. anyone got any other ideas??? because im clueless
thanks
a bunch
Old 06-15-2007, 09:12 PM
some more video clips from before i tore it apart
http://s2.photobucket.com/albums/y39...t=P1010331.flv
http://s2.photobucket.com/albums/y39...t=P1010330.flv
the noise isn't that distinct on these videos like it is on the first one.
in the first one you can hear it once i let off the gas and the RPMs drop it makes a flutter sound.
i wish i could have got a video of it with my video camera instead.
anyone got any ideas as to what it is?
Old 06-15-2007, 09:30 PM
v8
17,16,15,14,13,12,11 Drvr
rist pin is the problem.
Quick Reply: wierd motor noise vid inside
