Who's running Baer Alumasports?
I've had a set since Styling Concepts first started shipping them several years ago. Got about 25k of abusive use with no problems except minor cracks in the rotors. Baer worked me a deal and I replaced them when the pads were done.
Unfortunately, I can't get them to stop squealing. Baer doesn't have a fix except change to the newer ceramic pads.
The first set lived a hard life of stopping a 5400# truck hard and fast, but never made any noise. The second set makes so much noise in stop and go traffic that it is extremely embarrassing. This only happens at slow speeds below ten mph to zero.
Anyone having/had these squeal problems?
Another note: if your squealing is when you apply the brakes, then it's your pads. You could try some anti-squeal or some news pads properly installed with anti-squeal.
If the squealing is all the time, no matter if braking or not, then you have an interference problem, as I mentioned before.
The squealing is only with light braking pressure from 10-15 mph to stop.
I have re bed the brakes once.
The ceramic pads (which are the only ones they sell now), are supposed to have the same coefficient of friction when hot as the original pads but need to have heat put in them to achieve the #. The pads I have are the original type that grip hard hot or cold but produce a lot of dust.
I don't mind the dust too much but can't stand the noise.
Like I said in my post, Baer can't give me a solution to the noise.
