who has an Optima Battery?
Old Apr 27, 2004 | 02:34 PM
KeukaZ71's Avatar
Default who has an Optima Battery?
just put one in my truck yesterday and i can't get it fastened down very good like the stock one. it jiggles real easily. anyone have this problem? what did you rig up to fix it?
Old Apr 27, 2004 | 03:07 PM
MacADaYear's Avatar
I used my stock stuff and mine dosent move at all. I have a redtop.
Old Apr 27, 2004 | 03:28 PM
KeukaZ71's Avatar
i have a yellow top, but it should be the same exact battery size, just a deep cycle. i put the stock thing back in the is supposed to hold the battery in place, but the battery still moves. did you wrap the foam covering around the battery that was around the stock battery?
Old Apr 27, 2004 | 03:30 PM
MacADaYear's Avatar
No I didnt reuse the foam
Old Apr 27, 2004 | 04:08 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Keuka, so you're saying that the black plastic piece isn't holding it down securely?
I just swapped mine out, no problems. The black plastic piece is supposed to go over the bottom lip of the battery and you just bolt it down.
Old Apr 27, 2004 | 04:09 PM
yellowls1truck's Avatar
No problems with mine here. Simple R&R procedure.
Old Apr 27, 2004 | 04:30 PM
ThunderZ28's Avatar
12 Second Club
no problems with my red top. bolted down with the original hardware
Old Apr 27, 2004 | 04:43 PM
Tokez420's Avatar
no problems here with the yellow stuff.....all original hardware
Old Apr 27, 2004 | 04:56 PM
sleepersilverado's Avatar
i did not have a prob either. did you make sure you had the front lip of the battery under the hold? i also thought i heard at one time they had diffrent sizes or something dont know though.
good luck
Old Apr 27, 2004 | 05:10 PM
mwalls54's Avatar
Need More N2O Mod
no problem here either
