where did the coolant go?
Old 11-21-2011, 12:26 PM
50kta's Avatar
Default where did the coolant go?
first, back story.
a month ago i blew a heater hose and over heated the engine.
i replaced water pump thermostst, and while i was at it i replaced the knock sensors.
i bled the coolant system the correct way ( with the yellow funnel)
now here it is a month later and i have a low coolant message, im a little less than a half gallon low. i have check every where for leaks, water pump steam pipe, hoses, no signs of a leak under the truck?
now i notice when i first start the truck it blows white smoke out the exhaust until it warms up?
Old 11-21-2011, 01:02 PM
Slammed96's Avatar
Im gonna venture to say you probably warped one of the heads when you overheated. Not much, but enough to cause coolant to leak into the cylinder until the block and heads expand enough to seal again.
Old 11-21-2011, 01:12 PM
I have a gauge for that
Atomic's Avatar
yep...leaking into the cylinder, have the heads milled flat and new headgaskets
6.0l RST
11-23-2015 11:30 AM
bearden86
26
11-15-2015 03:58 PM
sTNT971
09-26-2015 04:22 PM
Bluecollar Hotrods
07-16-2015 08:52 PM
Quick Reply: where did the coolant go?
