What could these metal bits be?
Old Sep 20, 2012 | 06:30 PM
Suburbazine's Avatar
Default What could these metal bits be?
So, I was draining the oil and when I pulled out the drain bolt, I found these little heartwarmers attached. I've taken off the valve covers and checked the springs, retainers (and seats as well as I could) and didn't find the source. However, the size of the bigger piece almost perfectly matched the outer edge of a retainer and I'm leaning toward it being valve spring seat.
http://imageshack.us/a/img35/5397/img0120ipw.jpg
HUGE IMAGE
Old Sep 20, 2012 | 10:03 PM
swift700's Avatar
I would say you are correct.
Old Sep 21, 2012 | 02:26 AM
I'm fairly certain #5 is the culprit as I don't see the seat poking out from under the spring anymore. I'm going to send it to the machine shop and let them replace all the retainers, locks, seats and seals on both heads.
Old Sep 23, 2012 | 01:10 AM
Ferocity02's Avatar
Looks like a seat to me also. It's easy to replace those bits yourself. No need to pull the heads even unless you suspect valve damage.
Old Sep 23, 2012 | 02:37 PM
Yeah, it is a piece of seat and apparently a chip off a timing tooth.
Odd thing is, I haven't had seal seats (that's what it's from) since I went dual springs 25,000 miles ago. I have shims under there now and it's definitely not a shim fragment. I'm guessing it must have been stuck somewhere in the engine until I poured a can of Seafoam in the oil.
03sierraslt
14
Oct 9, 2015 05:53 AM
Velocity1
Oct 2, 2015 08:01 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Wrecker 426
Sep 29, 2015 11:00 PM
lxcoupe
Sep 25, 2015 12:36 PM
