what controls the overhead dome when the key is removed?
Old Feb 2, 2011 | 03:59 PM
GMCtrk's Avatar
Default what controls the overhead dome when the key is removed?
For some reason my in-cab light isn't coming on when I turn the truck off. The light does come on when I use the key fob to unlock the doors. Thanks.
Old Feb 2, 2011 | 04:26 PM
_zebra's Avatar
makes children cry
there's a "door open" switch that's probably malfunctioning.
i don't exactly know where it is on our trucks, though. sorry
Old Feb 2, 2011 | 04:40 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I can't remember what year your truck is.
Old Feb 2, 2011 | 04:52 PM
Mrgoodwrench3's Avatar
What year?
Old Feb 2, 2011 | 10:15 PM
GMCtrk's Avatar
And I wonder if it does have something to do with the door because it started malfunctioning after my window got busted in and I had to pull the door panel off several times.
Old Feb 2, 2011 | 11:27 PM
_zebra's Avatar
makes children cry
if it's like the vettes & has a sensor in the latch, take the panel off again & make sure the connector's in & making good contact
Old Feb 2, 2011 | 11:38 PM
I'll post up a schematic for you.
Old Feb 3, 2011 | 12:34 PM
Michael, there are 2 different schematics. One for base model, and one for uplevel. If I printscreen and post it up for you, you won't be able to read it since the print will be too small. If you pm me a fax number, I'll fax it to you, if that helps.
On the 2000 GMC, your courtesy lamps are tied to the retained accessory power. This is how it should work. You park and turn off the key, the radio should continue operating. If you remove the key from the ignition(before opening any door), the courtesy lamps should turn on. Then when you open the door, the radio (running on retained accessory power) should turn off. Of course the courtesy lights will stay on, the door is open. After closing the door, they should stay on for about 10 seconds, then go out.
Be sure to post up what you find wrong.
Old Feb 3, 2011 | 12:46 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Where do you find good wiring schematics for these trucks? Im trying to track down a fuel pump gremlin. Where did you get the door switches at?
Old Feb 3, 2011 | 12:57 PM
Mitchell On-Demand. Monthly subscription for my business is $239/month.
