what is a 2-step and how does it work?
#21
if you had a super rich AFR, which is what you would have if you dumped 4 cylinders with fuel but no spark, it will spike the EGTs very high. and that in turn will make the turbo hot and help it build boost.
i finally got my head wrapped around this.
you could only increase the two-step rpm up to the point of absolute rpm flash on your converter, right? otherwise, you would push through your front brakes, right?
from what i read about trans-brakes, you can only rev up to what your converter will allow, then it would start to push through the brakes.
#22
you'd break the tranny before it will push through the brakes. You're thinking of foot braking which is much different. A trans brake holds the transmission from moving, which I believe it does by activating the forward and reverse clutches at the same time, binding the transmission until you release the button. It creates ALOT of heat.
#23
what a T-brake does is put your transmission and drive and reverse at the same time, essentially locking the transmission up. when you let loose the button it takes it out of reverse and all hell breaks loose.
#26
ok it wont push through the brakes but it will only rev as high as the converter will allow it to slip.
i know what a t-brake does, dont know why i was thinking of foot brakes, lol
#28
