were kind i find power
Old Nov 12, 2015 | 06:43 AM
mikem8560's Avatar
Registered User
Default were kind i find power
my overhead console on my 05 gmc had the cubby hole removed to i want to add a gps in its place but need power that turns on with the key i think the lights have power all the time with the motor off
is there a easy access to power ?
could i find power in the review mirror with the key?
Old Nov 12, 2015 | 07:19 AM
Atomic's Avatar
I have a gauge for that
Easiest thing will be to use an add-a-fuse in the interior fuse panel on a circuit that is activated with the key (instrument cluster, for example), and then run a wire from that up through the a pillar behind the headliner over to the cubby.
Old Nov 12, 2015 | 11:01 PM
mikem8560's Avatar
Registered User
thanks that what I ended up doing
Old Nov 13, 2015 | 12:19 AM
Pull down the overhead cut the harness open dropping to the mirror and hit the pink wire you'll get switched 12V.
TXjeepTJ
28
Dec 31, 2019 08:53 AM
03sierraslt
Nov 12, 2015 10:39 PM
SSpeeDEMONSS
Nov 9, 2015 06:50 PM
sleek silverado
Nov 5, 2015 02:48 PM
