Some recent IAT findings
Old Nov 9, 2015 | 08:18 PM
03sierraslt's Avatar
Default Some recent IAT findings
So I have not been to the track for a couple years, so I really havent done any long WO pulls. Couple weeks ago I went to the track and found that my IATs were rising 75 deg from start to finish, they never used to do this. Now Ive changed quite a bit since last time at the track including raising boost so...... Long story short I was making more heat then my heat exchanger could handle. I went to a Lingenfelter Verimax pump and added a second HX. Now my IAT's rise 24 degrees on a 0-120 pull. Interestingly enough, they peak at like 95mph and then just flatline.
Kinda sucked, the truck was running strong on blasts on the road just didnt stay in it long enough to notice iats going crazy. I could feel it at the track loose power once I hit the 1/8m. I seen 189 deg iat at the end of the pass.
Today after a 0-120 pull they peaked at 99!!!!! Just wanted to share incase anyone is fighting high IAT's. Joe at leftcoast32 took care of me, when I talked with him about it he said right off the bat that I was making too much heat for the one HX. Tracks are done for the year so ohhh well.
Old Nov 9, 2015 | 08:24 PM
1FastBrick's Avatar
Custm2500's Rude Friend
what, no pictors of the set up???
Old Nov 9, 2015 | 09:30 PM
ZO6Ted's Avatar
This is GREAT news! Bet it's way stronger next time out. Can't wait to see but either way it's a big win. Congrats!
Old Nov 10, 2015 | 08:44 AM
Atomic's Avatar
I have a gauge for that
I remember when I was messing with heat exchangers on my old setup I didn't see much improvement with a larger cooler, just faster recovery times. My peak temps didn't change much.
Here are my old threads:
https://www.performancetrucks.net/fo...-boost-465418/
https://www.performancetrucks.net/fo...p-test-463783/
Old Nov 10, 2015 | 09:23 AM
Well my results are much different thankfully.
Old Nov 10, 2015 | 09:36 AM
Vortec350ss's Avatar
Could this be where the higher volume pump is changing the results you both saw? My guess is yes.
Atomic's Avatar
Yea, I wonder why haha. I really want to do some testing on my whipple to see how it does...you aren't spraying any meth, right?
Old Nov 10, 2015 | 09:54 AM
he has a single 15gph nozzle
Old Nov 10, 2015 | 10:01 AM
George C....'s Avatar
Formerly ScreamingL
Lightning guys dont bother with heat exchangers but instead go larger ice tank, larger intercooler lines, and larger intercooler pump
Old Nov 10, 2015 | 10:06 AM
rrmccabe's Avatar
Can always count on Joe to point ya in the right direction.
