Valve Spring compressor Tools
Old Apr 5, 2012 | 02:54 PM
iamkeniff's Avatar
We have the comp dual spring tool, but i made my own plate like Atomic mentioned. Its done a ton of valve spring jobs with no issues!
Old Apr 6, 2012 | 09:40 AM
1Bear's Avatar
While the dual-spring Crane/Vinci style compressors work well, keep in mind that if you plan on using one for multiple engines; i.e. cathedral port heads and/or rectangular port heads you will need more than one tool, as the spacing of the rocker stands are different between the two. This is where the tools like those available from Lingenfelter shine, as they simply line up with each single valve-spring. No, you will no longer be able to work two at a time, but it’s no great inconvenience.
While in a pinch, the simple little claw type auto-parts store will get the job done, they are best left to engines that have single-coil springs. They are just too much a pain in the rear to use on a dual-spring and one stands too great a chance of then slipping and possibly causing you to drop a valve, shooting a keeper across the garage or down in the head, or worse possible injury. Forget trying to use one a head with triple-springs, as it aint going to happen. Tools like these are something you can keep in your favorite box for years to come, so you might as well spend your money wisely and get one that you will be proud to own and use.
Old Apr 6, 2012 | 07:41 PM
TIM Z's Avatar
11 sec. Truck Mod
Ive always used the crane tool with great results,
But ive been looking at the new ones by Comp and Trick flow in the summit catalog, the Trick flow is pretty decently priced.
GXPJAY
Feb 13, 2022 08:15 AM
chopperloco
Jul 10, 2016 10:45 PM
silverstreak07
Jun 28, 2016 06:29 PM
Mzay
Jul 6, 2015 11:05 PM
