Vacuum at Dipstick??
Old Jun 17, 2011 | 07:36 PM
Steve-O-08's Avatar
Default Vacuum at Dipstick??
My truck has been making a slight whistling noise occasionally on acceleration and I can't seem to pin point the source. It does not sound like a belt or bearing. I was looking around under the hood today and it seems like I have vacuum at the oil dipstick. I don't ever remember it before. Anyone experienced this before? could this be the source of my noise?
Old Jun 17, 2011 | 08:38 PM
Vortec_psi's Avatar
I once had a slight whistle from a vac leak on my truck and it turned out to to be a blown intake gasket. When you pull out the dipstick does the trucks idle change?
Old Jun 17, 2011 | 09:18 PM
OUT2WIN's Avatar
Its from the Nitrous plate. We installed 3 nitrous kits on 3 different trucks and they all did that. 2 kits were Nitrous Outlet and the other was a Harris Speedworks. 2 of the trucks just put a breather where the dipstick goes and the "whistle" went away.
Old Jun 17, 2011 | 09:43 PM
Steve-O-08's Avatar
How would the plate cause a whistle? I know it's sealing to the throttle body correctly.
Old Jun 17, 2011 | 09:46 PM
OUT2WIN's Avatar
I have no clue but as soon as we took one off it went away
Old Jun 17, 2011 | 09:48 PM
Gadgetized's Avatar
Crankcase vacuum is normal. Remove the oil cap when it is running, and see if the whistling goes away. I wouldn't leave it off for long though.
Old Jun 17, 2011 | 09:53 PM
Steve-O-08's Avatar
The whistle is only noticeable under load, And is somewhat intermittent.
GMCtrk
18
Oct 6, 2015 03:48 PM
kmcn47
Sep 17, 2015 01:12 AM
Velocity1
Sep 15, 2015 11:29 PM
2500ZL1
Sep 12, 2015 03:50 PM
cousblake11
Sep 9, 2015 06:52 PM
