V6 to V8 Swap: Wont Start
Old Dec 15, 2006 | 03:56 PM
Nick™'s Avatar
VATS will do the following when it's activated it will allow the fuel pump on and the motor will crank and as soon as it fires off it shuts down.
On Matt's 2000 it fires right off and dies, on an old neighbors Camaro (4th gen) it would fire off and die 3 seconds later.
Old Dec 15, 2006 | 03:57 PM
gao8302's Avatar
From what i understand of Vats is that it will start and then die. I have seen it first hand. I willing to bet that you need a crank relearn done.
Old Dec 15, 2006 | 04:00 PM
Dirty 30's Avatar
LS1Tech Whore
Originally Posted by 1BADC10
Matt... bring a fuel pump with ya! Don't ever run that truck with 2 gallons of gas in it again!
The truck did have about 1/8th tank left. :hmm:
Old Dec 15, 2006 | 04:03 PM
Dirty 30's Avatar
LS1Tech Whore
Well its actually a 5.7L LS1 with 5.3L heads and all the 5.3L accessories and wiring. When I turn the key it cranks and you can smell fuel thru the exhaust but it wont fire the cylinders.
Could it be that the BCM from the V8 have a different value for the Passkey 2 than the one on my V6 BCM??? Cause i hooked up the wiring and BCM to my original steering column.
Dirty 30's Avatar
LS1Tech Whore
Doesnt that require the truck to actually idle???
Old Dec 15, 2006 | 04:05 PM
gao8302's Avatar
that will happen, you get so tied up in the install that you will forget the obvious!! Been there done that
Old Dec 15, 2006 | 04:06 PM
Dirty 30's Avatar
LS1Tech Whore
Originally Posted by thunder550
Here are some threads to check out. If you didn't follow the relearn procedure exactly it won't work
https://www.performancetrucks.net/fo...highlight=vats
https://www.performancetrucks.net/fo...curity+relearn
Make sure doors are all shut and accessories are all off. May want to hook up a trickle charger too, as it may take some time to do.
6.Once this entire procedure has been completed (three times) your vehicle will start on the fourth attempt.
I did exaclty as it says.
The light does go away on the 3rd try and I turned the key off 20secs then on on the 4th and the light wont come back on anymore but still wont start.
I changed out the Fuel pump relay, ignition relay, injector relay and still nothing.
Old Dec 15, 2006 | 04:08 PM
thunder550's Avatar
High on diesel fumes
You sure you got the injectors all plugged in the right order? Check your spark again like I said above, ground the plug electrode to a clean metal surface.
From what you are describing it sounds like the security relearn worked, but you're having a different issue. We know your fuel is good, we need to double-check spark.
Old Dec 15, 2006 | 04:09 PM
Dirty 30's Avatar
LS1Tech Whore
Im pissed off and sad cause i worked so hard installing it then this happens
gao8302's Avatar
did you put the engine together? And are you sure that every thing to put together right?
