Two battery setup
I installed a pulley system on my 1999 2door 2wheel drive yukon. The problem now is that i cant get up to 14 volts on my gauge. The truck came with an extra battery tray. How do i go about connecting the other battery to my existing system?
No, because your alternator is putting out the correct voltage much less 14 volts. Do what Thunder said and find a smaller pulley, I thought most UD pulleys come with a smaller alternator pulley. Also put a voltmeter to back of the alternator and check your voltage there, you might have bump the connector on the side (feeds your voltage gauge) or something.
drummer0415
11
Oct 24, 2015 08:16 PM
muncie21
Sep 7, 2015 09:55 PM
