turn signal stalk
Old Nov 23, 2006 | 06:52 AM
shawn's SS's Avatar
Default turn signal stalk
Has anybody replaced their turn signal stalk? Did you have to remove the steering wheel? I'm adding cruise control is why I ask. Thanks
Old Nov 23, 2006 | 06:59 AM
Grumpy5.3's Avatar
yes you will have to remove the steering wheel, you are gonna have to change the entire multifunction switch(technical name).....
Old Nov 23, 2006 | 09:37 AM
shawn's SS's Avatar
Damn, I was hoping I wouldn't have to remove it! I've already got the new stalk, i',m just a little bit worried about setting the air bag off
On a side note i noticed you have a 2/4 drop. What brand off drop did you go with and do you have to c-notch? Hows the ride? I want to do the 2/4 drop myself but want to keep the stock ride if possible. The mcgaughys kit sounds like the best for me.
Old Nov 23, 2006 | 01:45 PM
Grumpy5.3's Avatar
It is Mcgaugys spindles, shackles and hangers, no c notch.... It is a little bouncy, but I have stock shocks.
Old Nov 23, 2006 | 05:17 PM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
I wouldnt really worry about setting the air bag off, look down under you dash by your gas peddle/brake peddle and you should see a yellow wire (airbags wires are always yellow) the yellow wire should have a plug in it so you can disconnect it if not it should be right under the steering wheel column cover
Old Nov 20, 2007 | 02:01 PM
LJO's Avatar
LJO
You shouldn't have to remove the wheel, just get creative with your torx bit. For example the bit alone and a 1/4 inch open end wrench. I have never removed the wheel for replacing a m/f switch. Also turn steering wheel to allow the most access to the bottom torx screw.
dsbodley
Nov 14, 2015 09:46 PM
smok'nZ
Oct 6, 2015 01:14 PM
turbo6c3
Oct 5, 2015 06:11 PM
Chevy305
Sep 28, 2015 09:21 PM
trevorh1
Sep 27, 2015 08:47 PM
