Turn engine off-knock-rattle noise!
Old Aug 16, 2007 | 09:37 PM
TylerCustoms's Avatar
Default Turn engine off-knock-rattle noise!
Why is it whenever I turn my truck off for like 3 seconds it rattles like the trannys loose or something lol...does anyone elses 5spd do this? its never happeend to any of my auto trucks?
Old Aug 17, 2007 | 12:57 AM
budhayes3's Avatar
PT's Slowest Truck
When you shut it off, do you have your foot on the clutch or is the truck in neutral? Depending on how you do it, try it the other way and see if the noise is still there...maybe there's an issue with the clutch assembly? (broken/loose pressure plate spring or throwout bearing to pressure plate clearance?)
Old Aug 17, 2007 | 07:56 AM
hirdlej's Avatar
Mine does it too if you leave it in nuetral (ie reaching through the window while idling to shut it off). Push the clutch in and have it in gear while shutting it off, then let the clutch out. It's fine
Old Aug 17, 2007 | 08:43 AM
Ohh okay, yes i do this when its in neutral, havent tried pushin in the clutch and turning it off..ill try it later!
03regcab sierra
20
Aug 3, 2015 12:11 AM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
bsgiffor
Jul 19, 2015 11:14 AM
Suburban2500
Jul 14, 2015 02:10 AM
rojeho
Jul 12, 2015 06:10 PM
