truck wont start. help me out guys
Old Sep 13, 2010 | 10:41 AM
  #21
bow tie guy's Avatar
[QUOTE=skeet;4538531]sounds like bad gas, throw a couple more gallons in of some good gas and some water treatment, just went through this with my daughters car,
the sucurity light is flashing, it's security related
do the re-learn procedure
google is your freind
Not to mention SEARCH fearure this no start after
battery swap is as common as herpes .............Si no
Old Sep 13, 2010 | 12:20 PM
  #22
skeet's Avatar
Originally Posted by colekill
it blinks security when the door is open but not when its closed. however when i close the door and look it with the factory alarm it blinks security again.
here's a video of what its doin.
[QUOTE=bow tie guy;4538546]
my z71 with the door open will blink the security light, and when the alarm is active with the door closed it will also blink the security light ( go figure )with the door closed and alarm is deactivated it will start right up no security light blinking though.
but no doubt its worth a try..
Old Sep 13, 2010 | 01:48 PM
  #23
Krazy Ken's Avatar
I agree with what the other guys have said. After watching the video its either VATS or Fuel pump. I had VATS completely taken out of my truck because it used to be a v6 and the Security relearn wouldn't work for me. I would try to start it once and let it try and fire and after it has go press the shrader valve on the fuel rail and if it stil has Good pressure its VATS. Just as a precaution if it still has good pressure its going to squirt gas everywhere so cover your eyes.
Old Sep 13, 2010 | 10:01 PM
  #24
fredkj3's Avatar
check the dang pressure.... i used refrigeration guages....
Old Sep 15, 2010 | 04:44 PM
  #25
colekill's Avatar
KickinAssAndTakinNames
so just checked fuel pressure, reading 65 pounds when i turn the key on, and when i crank it for the short amount of time i can it, drops to about 53.
= good right? humm what next?
the injectors are getting there signal pulse to squirt
and the security light stops flashing whenever the key is in.
Old Sep 15, 2010 | 09:58 PM
  #26
Tootall's Avatar
Have you done the security relearn procedure?
Old Sep 16, 2010 | 12:15 PM
  #27
colekill's Avatar
I was about to but security light dosent flash when the key is in. And it said start it then leave the key on and wait 10 min till it stops blinking. Plus the injectors are working. It's gettin spark, fuel, the right fule pressure.
Not sure what to check next.
Old Sep 16, 2010 | 03:00 PM
  #28
does it die when you release the key to run position? if yes youtes might want to invest in an ignition switch
truck won't start after new battery in google results = security re-learn
disable vats brings back a plethora of like results
I doan know about you, but my next mod is disable vats via pcm program ........I doan need no VATS and you?
Old Sep 16, 2010 | 04:45 PM
  #29
colekill's Avatar
no it will die before swith the key back.
So is VATS just part of the factory alarm?
Old Sep 16, 2010 | 09:28 PM
  #30
Krazy Ken's Avatar
With VATS It still enables the ejectors to squirt for the enitial start up it just does not allow them to spray once the vehicle tries to start. (I took the intake off to look at the enjector spray when i had my VATS problem, all of them spray for a split second then stop.) Vats = (V)ehicle (A)nti (T)heft (S)ystem. From my understanding the ECU sends and recieves a signal to somewhere in the cab and if the codes or signal are not correct it won't allow it to fire up. (Correct me if im wrong guys) Its so someone can't steal a motor out of a truck and put it in another without the ecu getting ticked. Get ahold of someone with HP tuners or something and disable it. I am almost willing to put money on it.
