Truck wont start *NEW VIDEO ADDED*
Tin Foil Hat Wearin' Fool
Got everything done and tried to start it, but it just wont fire off.
Ive got fuel pressure(58 at the rail)
Checked all grounds
Pulled the shrader valve and purged 2 gallons of gas out til it smelled good, it had 2-3 gallons of old gas and 5 gallons of new 93, I tried to start it before purging and when it didnt start I added an additional 5 gallons of 93 and purged it some more.
My dad said the test light flashed when I I was trying to start it(stuck in a plug wire) so Im pretty sure Ive got spark. Ill confirm tomorrow with an old spark plug
It would turn over and as it turned over more and more it sounded like it would almost catch and want to start. Even a couple times it puffed some smoke out the tailpipe.
I didnt have my laptop with me to scan the computer to check if there was anything going on.
It used to have a 420 an 80e now its back to an LQ4 and 60e. Nelson is doing the tuning. Im going to try swapping a totally stock PCM in and see if that does anything. Ive never had to do a case relearn or whatever the hell its called when you install a new PCM. Ive always tossed in the computer and it worked fine but Ive read of a few people having problems. Ill look up the procedure for that I guess.
I didnt have a lot of time to mess with it a lot tonight but I took off early tomorrow so I can have more time to mess with it. Anybody think of anything I might be missing?
Video added to post 24
Checked all grounds
gt2-3, 7.4 pushrods, patriot duals
Im not sure what type of lifters are in there, they were just some xtras I had laying around from another build. Even if they were LS7 lifters my rods would be a little short so the valve thing wouldnt be a problem.
03 LQ4, gt2-3 cam, volant intake, built trans with tb converter, corsa catback is the full mod list right now.
After I confirm Ive got spark, if I do Im thinking computer issue of some sort. It should idle off a stock 5.3 tune? I knwo I wont be able get on it with a 5.3 tune but Id settle for getting it started right now.
im assuming stock rockers and you cant mess those up. the file would have to be totally jacked up for it to not fire. a stock file will fire it but not run well at all. check to see if you have good compression, cause you can have good spark and fuel but not fire cause its no compression. A stang recently did this and the rockers were to tight [adjustables], i also had this issues years ago and it was bent intake valves.
are you getting fuel to the plugs? pull a plug see if plug is wet
try some ethyer [sp] see if that hellps
do you have 58psi at rail? but ethyer will determine this. spray enough in there to see if it fires. if it fires you have a fuel issue
The 58psi is at the gauge on the shrader valve. Didnt pull a plug but I will tomorrow.
I know its atleast got a pretty good seal per cylinder since I had my air compressor hooked up to the cylinders with 150psi of air. Shouldnt have bent valves due to the tame setup Ive got.
